What to look for in a projector | SatelliteGuys.US
Sharpie
230
It is getting time for a new viewing system and have some questions about projectors. What should someone look for when considering getting a projector for the home theater? Lumens, contrast ratio, etc...... Thanks.
1. Budget
2. Room size, setup, windows - ambient light control
3. Projector format/native display/connection options
4. Projector Lumens
5. Projector contrast ratio
6. Projector mounting options
7. Screen needs
I recommend this model by far:
http://www.projectorcentral.com/Sanyo-PLV-Z4.htm
If you have easy controled light, you can save $$ by going with last season's Z3.
I have the Z3 and it is awesome. 106" - 250" of pure HD greatness for less than $2100 complete.
I also recommend this screen for typical everday use:
http://www.dalite.com/products/product.php?cID=9&pID=237
52" x 92" - 106" in High Conrast Matte White
or
http://www.dalite.com/products/product.php?cID=9&pID=230
HDTV Format Section also in High Contrast Matte White
call Robert at ValueElectronics.com and tell him Chuck at ChucksCoffee sent you.
No PS3 at CES... (well, not so surprising...)
New Sony KDF-E42A10 RP LCD TV, burn-in (period)
