What is a good way to add grip to the mounting pole to keep a motor from sliding down when in use
Not familiar with motorized dishes, but isn't there a way to bolt it? Seems a piece of all thread through the pole would keep it in place somehow.
I use a piece of wire hanger to support the motor bracket from the top of the pole when the clamps are loose.
<img src="http://www.satelliteguys.us/attachment.php?attachmentid=92235"/>
http://www.satelliteguys.us/threads/258050-Beefing-up-the-SG2100-bracket
You can make it stronger![]()
Red Green would be proud of you!I duct taped the top half of the pole prior to attaching the motor...maybe am lucky but no issues to far.
Limited time offer
