What type of Equipment? | SatelliteGuys.US
Mikemcq02
18
I have been DIRECTV for over 10 years and I have been "eligible" for equipment upgrade for quite some time. What is the latest equipment that I should expect or "request". I currently have HR24-200 in main room, a HR22-100 in main bedroom, H24-100 in basement and a standard D12-100 in a play room. I am sure I am way behind in equipment. Any suggestions? Thanks in advance!
hr-44 is the genie, you can have 1 per account
maybe swap the d12 for ir
the hr-24's are the next latest
Your upgrade will probably be a Genie (hopefully an HR44 not an HR34, you can't specify which although you will find lots of posts here about how to improve your chances of an HR44) plus some Genie mini-clients. My own personal recommendation would be to get clients to replace the H24 and the D12, but keep the other two DVRs. Or replace the HR22 with a client as well, if it's not performing well.
Changing Receivers
