When Voom goes off, does anyone know what channels will replace them and when will they be added?
Cablevision has said when they turn off the VOOM channels on the 20th that customers will not lose any HD channels, so I can on suspect the new channels will come on the same day.
I was just addressing the fact that the channels being lost shound be replaced by the end of the month. Some users believe that we will lose 15 channels for a while. Cablevision is supposed to be replacing them right away so there customers shouldn't feel the loss.
i hope they free up enough space to stop the over compression
Then they'll need to remove some more analog channels, otherwise not going to happen. If some analog channels are removed then one can expect the replacement channels to not be on SDV. Otherwise whatever replaces the VOOM channels will most likely be SDV, since CV needs to free up some more space.
Limited time offer
