Whats a good el-cheapo box? | SatelliteGuys.US
gadgtfreek
22,105
865
Lower Alabama
We only have one 622 now on 1 tv, I'd like to buy a box as a spare in case the 622 craps out. Any recommendations for a good reliable older model box(does not need to be a dvr).
Yeah, I was just about to post and ask about the 5000, dont think thats what I was looking for.
Seems like they have 301's on ebay for mid $30's. I think I bought one of these from Radio Shack for a xtra box a couple of years ago when I had DIsh in my previous town. That would serve me fine, I have ota but would like to have access to sat channels for the few days my 622 would be down.
So the 301 would see the sats thru my 1000.2/500 without issue?
Thanks.
Also, I see some auctions that state no smart card. I need one with a card correct? Or can I take the card out of the 622?
Also, when I get the spare, can I call DIsh to confirm the receiver is ready to go(aka not stolen or something else) by given them the rec #.
You can not take a card out of 1 box and put it in another. They are "married" to the box. So you want to make sure that you get one with a card. And yes, it will work just fine with your 1000.2 setup (but you won't see any of the HD channels obviously).
The 311 has the card built-in, the 301 doesn't. I would go with the 311 so you don't have to deal with the smart card, specially since you want to get them on eBay.
Yes, in fact, one annoyance is that SD boxes do not show listings for HD channels that you subscribe to. So, when I am not in the living room, and using the 721, I cannot check the Guide about what will be showing in HD in the future. :(
Now fold the door in half and see if you see the card now. If not, roll the door up and try stretching it.
Charlie Chat Monday, with Chriss Angel
non entry to win a dish 222 reciver
