whats my problem? | SatelliteGuys.US
whats my problem?
Not open for further replies.
M
maussimo010
Guest
thanks to anyone who reads and or helps:
Dish Network, dish 500
Front room Receiver: 3900 upgraded
bedroom receiver: 2700/3700/2800
i lost my 110 channels last night, sunday the 29th, and thought it was inclement weather.
I only lost signal in the bedroom, not to the front room
next day they still arent back yet.
i check my switch cable going to my room, as sometime humidity causes the connection to corrode, and it was grimy, so i cut off bad cable and put new end on it, then reattached it.
still no 110.
ran a switch check, and this is what i came up with:
Input: 1 1 2 2
Satellite: 119 119 110 X
Polarity: Odd Odd Odd X
Status Problem detected, check connections
any other info as to what this means and how to fix is tremendously appreciated, and if u need more info, please let me know
i am also hopin to not get answers like, u have a bad switch, replace it...u have a bad cable/receiver...replace it...this has happened on occasion before, but was so long ago i forgot what i did to fix it...
thanks again so much, scott... please reply here or in private at skawalker@gmail.com
Part of the problem is you posted this in the wrong forum. This needs to go to the DISH Network forum.
This forum is for help with the website itself.
sorry bout that...was in such a hurry to get it fixed hopefully i thought help desk meant help desk for satellites...very sorry...
Not a problem!! We always encourage questions. We are here to make sure people like you get the help they need. I don't have moderator capabilities for this part of the board but if I did I would have moved it to the technical support forum.
I just wanted to let you know that you had it in the wrong forum.
