What's up with the DVI again? | SatelliteGuys.US
gutter
1,510
This morning. all the SD channels have black on the left side and top. I had this problem on DVI with I first got VOOM. Changed to Component and it was ok. about 6 weeks ago I changed back to DVI and was suprised to see that the old problem wasn't there anymore. It filled the screen nicely. Now it is like it was.
Sean are they doing more checks. I have my STB in native mode. When I used to change from a 1080I to a standard 480I. the STB would blink when the resolution changed from chaning channels. Now it does not. Is VOOM Tech making other changes?
I have a Samsung DLP.
I am seeing the same thing here. I'm using DVI with a JVC 48" TV. It wasn't like this last night. I sure hope this isn't another so called "Good thing" that's supposed to come from the new encoders. I hate to be so negative but right now with the bad PQ I am on the fence. If things don't improve soom I'm dumping Voom. This new problem doesn't help things. Anyway your not alone. I see it too. I am using 1080i mode.
What will happen to the equipment?
received response
