Guys, I have very strange issue. When I use Vbox I get No signal for Certain KU TP's. But if I directly connect the receiver I have very good signal for the same TP. And also I have noticed that when its connect to the Vbox and when I go very close to Vbox for some of the torouble some TP's my signal gets improved. When I moved away again no signal. Pls see the below video.
I have tested this. It happens not only for a single satellite. There are some other TP's even if I go very close to the Vbox I get no signal. But when I connect directly it gets very good signal. So I thought it has something to do with Vbox. So I changed it to ACS1. But that also gives me same strange issue. Then I changed the receivers. Still same issue.
However I didn't notice this issue with C band.
Here is how I connect it to VBOX
How to get this fixed ?
