When should I cancel Voom? | SatelliteGuys.US
Kyrak
6
Unfortunately I am moving cross country into an apt for about a year and will be leaving my theater and Voom behind. When is the best time to cancel? I think I remember reading that they don't pro rate anything when you cancel. My billing cycle ends on the 6th of each month. Does it go by the deinstall order time or when the dish is actually removed? i.e. do I need to set the deinstall up for the 5th?
Thanks,
Kyrak
Cancel date
If your moving out on the 5th, then you can call and cancel service now, just have the CSR make sure services are active until then. As far as cancel dates go, your account stays active until the equipment is picked up and the Work order is turned in by tech, then charges are prorated back to the cancel date. If your services run into the next billing cycle then you will be billed again, but those charges will be refunded back to you. Services are not disconnected, ie: no signal, unless the agent sends a hit to your box after the disconnect work order is created.
Oh ok, I didn't think they pro-rated after a cancellation for some reason. No hurry then. I am not moving until the third week of April, but would cancel early to avoid paying for a full month if it wasn't pro-rated.
Kyrak
VOOM receiver will not boot up!?!
Definition of HD
