Patience, Son, patience.Can anyone answer the question?
http://www.satelliteguys.us/dish-network-forum/167119-vip922-demostration.html
I was hoping the sling featuring would allow you to watch HD TV in other rooms. As for multiple HD outs, AT&T does it with UVERSE right?
Then whats the point of Sling? I'm confused.![]()
I was told last week that the release has been pushed back until June.
It will be a few years before we see 2 HD out receivers. At the monent it is cheaper for dish to put in 2 hd boxes then it is to make a receiver that outputs 2 hd streams.
Scott,
I may be mistaken but I thought that I saw the 922 being able to do 2 hd outputs.Dish has a monitor that you can buy and its suppose to be slinged from the 922.Is this sling standard def only?If thats the case why would anyone buy the monitor if its only going to be standard def?Thanks![]()
Its cheaper for the customer if they made the 922 have 2 rooms of HD.At the monent it is cheaper for dish to put in 2 hd boxes then it is to make a receiver that outputs 2 hd streams.
HDMIJust in what form are they to get HD to the second HDTV?
HDMI?
Component?
ATSC?
Each has problems with either cable cost, oscillator/encoder cost, etc.
It is still better for both subs and Dish to use seperate receivers for each HDTV.
And I don't see a great enough demand for the development costs to be covered.
Limited time offer
