Where can I buy a cassette adapter for the Orbiter?? | SatelliteGuys.US
SA31133
I just received the Orbiter for Chistmas, but am receiving too much static using the wireless FM mod. I heard the cassette adapter sounds MUCH better and would like to try it, but I am not sure what I need to buy and where.
Can someone post a link or give me some information.
I would really appreciate it.
Thanks!
I bought a cassette adapter at Radio Shack, although I eventually opted for the AudioVox FM Antenna Switch (I have a PnP2). You plug it inline with your radio antenna. Then you plug the switch into the FM out port on your Sirius unit. When you turn on the PNP, it "shuts off" your FM antenna an eliminates the static caused by the crossover. It works great. It only took me 10 minutes and the sound is great.
I understand that it will work with just about every radio that has an FM out plug. I ordered it direct from AudioVox at 1-800-229-1235. It cost ~ $20 with shipping.
Good luck!
