Where can I find this cable?? DVI to RGB | SatelliteGuys.US
runz22
34
I need a cable to go from the back of the VOOM box (DVI) to an RGB connection on the back of my tuner box. When I find a cable that I think is close the DVI side is wrong--strange pin configuration.
VOOM STB supports DVI-D interface, which is digital only. It doesn't have RGB component. Only DVI-I does. Sorry...
Thanks for the response. It stinks that my monitor has capability for better resolution but we can't take advantage of it because of connections.
You might be able to find a component-to-RGB converter, but those are rather expensive.
Try Cables To Go on the internet.
Vertical white bar on screen???
Any way to Stretch/Zoom OTA SD Channels?
