Where to find transponders for locals on 72.5 | SatelliteGuys.US
vfr781rider
57
Nashville, TN
Been looking for a link that would tell me which transponders on 72.5 are used for the local channels in Tri-Cities, TN-VA. Appreciate a link or some info if anyone should know. TIA.
vfr781rider said:
I'm going to show my ignorance here, but what the heck :) Those pages show 68 channels and 16 transponders. How do I know which channels are on which transponders? Thanks for the help.
You CAN'T find out from Lyngsat which channels are on which x-ponders. But you can from certain receivers - if you have a Hughes HAH or HBH series, just switch to a particular channel#, then go into the signal meter - the x-ponder that that last channel you just selected will be the one that initially comes up on the signal meter.
FYI - x-ponders 1-16 are the only ones in use on 72.5
What Universal remote works with SAT520
What Can I Do????
