I plan to totally disassemble the mount and clean all the rust with a wire brush then prime and paint it, but I dont want to risk busting a few of the adjustment screws. The mover on it I think is frozen solid, and I doubt I would be able to find a stepper motor for it. If not, I will probably park it on G10.Shawn95GT said:Poking around Lyngsat it's a tough decision.
I'll probably park on G10R for now and check out the Outdoor Channel.
As for rust.... It looks gimmicky as heck but I swear by Pro-Long if you can get it locally. It's just a penetrating oil though - you probably want something to get rid of the rust.
Shawn95GT said:What LNBF are you using? ASC421?
Well cool - I've got the same LNBF. I'll have it on the dish until I get a receiver that'll controll the polarotor for my C/Ku feedhorn (3500s is looking good).questic said:ASC-421 from PSB on 180cm Fortec from Sadoun.
I am hoping to "fix" the dish somewhere before dark, but that is fast approaching
shinnery said:The best rust penetrating oil I have found is Kroil. It is sold by Kano labs out of Nashville, Tn. I freed up an old tractor engine with it. They call it "the oil that creeps". I did have their email but i bet you can google it. Bryce
questic said:huh?
Limited time offer
