Where's NBC, FOX, ABC and CBS in FTA ? | SatelliteGuys.US
robosat
66
3
North of Mexico
Hi Guys...
I can watch NBC SD in G16 (99W) and NBC HD (Feeds) in AMC18 (105W); and CBS SD in G3C (95W).
What about ABC (HD or SD) and CBS HD ? (ABC HD Puerto Rico was recently removed from G16 (99W).
Are they in some other satellite? (C Band)
Thanks. Greetings...
See "The List" at the top of the forum page. Go to 99W C-Band and you will find ABC HD feeds in that listing. The list does not show it, but you can find CBS HD on 97W, but you will need a receiver that does 4:2:2 to receive those.
For CBS, isn't there still a mux on 95W? I can't remember the station but it had CBS, A spanish sub and something else or two in the mux. SD and easy to get on C-band small dish project.
You should be able to find all 4 on 137W Cband.
Please note that "The List" is so far out of date that it's almost useless. The last update there is listed as 10/10/2011 and most of the stuff that's listed is no longer there?
KTV2 Movie Tonight Maiden Heist
Need info on DTH 8600IR
