Hi,
New to the forums and looked around for an answer but no luck.
We have a dish network 500 with two receivers. #2 works most always except really bad weather. #1 with a 522 receiver sometimes works but has not for most of the past two months and presently has not worked at all for 5 weeks. Phone help is useless except for wanting to send out a tech.
We continually get an error 502 for a faulty switch. Switch check goes into the 38 tests for both 110 and 119. Cables seem good with correct length conductors both to the splitter and between the splitter and the 522.
My question is where do they put the switch? Is it on the roof with the dish? It's not in the basement or the tv room where the cables exit the wall.
Confused in upstate NY,
Gerry
Gerry
