Which Access Card? | SatelliteGuys.US
Which Access Card?
digitalgm
17
All, I am looking to get a HD reciever from eBay but I need to know what to look for. From reading on this forum, I am looking for a sealed P5 card, right?
AdamR
AdamR
I may be wrong, but the way that I understand it, if you don't get your receiver from Directv directly or one of their retailers like Best Buy, then you will have to call directv to get a new card. The cost is $20. Otherwise if you want to replace a receiver you can use the card out of the one your replacing. As far as I know D* has not started to phase out the P4 cards yet so you should still be able to use a P4 if you have one. They don't like to use cards that were registered to another user's account in case of any type of pirating.
Second dish needed for local channels?
Toshiba Receiver DST3000 Problems?
