Which Antenna for HDTV locals? | SatelliteGuys.US
Rook
24
Hello, here is what broadcasts I have:
* yellow - uhf WZPX-DT 43.1 i BATTLE CREEK MI 253° 28.3 44
* yellow - uhf WSYM-DT 47.1 FOX LANSING MI 197° 25.9 38
* yellow - uhf WLNS-DT 6.1 CBS LANSING MI 145° 13.4 59
* yellow - uhf WKAR-DT 23.1 PBS EAST LANSING MI 149° 11.5 55
* yellow - uhf WHTV-DT 34 UPN JACKSON MI TBD 183° 28.6 34
* yellow - uhf WLAJ-DT 53.1 ABC LANSING MI 183° 28.6 51
* lt green - uhf WAQP-DT 49.1 TBN SAGINAW MI TBD 49° 36.6 48
* red - uhf WILX-DT 10.1 NBC ONONDAGA MI 188° 27.2 57
* blue - uhf WSMH-DT 16 FOX FLINT MI TBD 49° 36.6 16
* blue - uhf WJRT-DT 12.1 ABC FLINT MI 48° 36.8 36
* violet - uhf WPXD-DT 31.1 i ANN ARBOR MI TBD 148° 40.1 33.
The website says small multidirectional antenna. Any suggestions as to which one? Do those $19.99 antennas that you place next to the t.v. work?
Also, anyone know if I can hook an OTA antenna to a Comcast HD/DVR receiver?
As to which antenna, all depends on what you REALLY need to receive. The yellows and some of the further ones would probably be best served by a silver sensor (VS sells these, and they're VERY highly regarded).
The NBC in red is a crapshoot with that antenna, it's only a $20 bet, so I'd say go for it.
As to your receiver, no cable-dropped boxes that I know of contain OTA. You'll need a seperate tuner, either from your TV or a seperate box.
erm, that would be V*E*, as in Value Electronics, as in a site sponsor. :)
(Going to get some coffee for that one...)
The Terk is the equivalent of a coathanger and the goXium is the equivalent of a coffee can.
Buy a real antenna that looks like an antenna and works like an antenna.
The small multi-directional will only get you the first 6 in the list. If that's what you want that's ok.
But please buy an antenna from a reputable manufacturer, like Channel Master, Wingard or Antennas Direct.
It will last longer and give much more enjoyment, probably at a lower price.
