Which antenna would be better? | SatelliteGuys.US
bkushner
681
2
Audubon, NJ
I am 13 miles from the towers and need a NON Amplified antenna. I'm looking at the Winegard Sensar 3 and the Winegard SquareShooter?
Which would give me the best performance?
brian
Antennasdirect.com 's DB2, Zenith Silver sensor.. a coathanger j/k
Your pretty close any small antenna should work fine.
The Square shooter would be overkill. Are all the stations in the same place?
