I am dangerously close to having enough money to order the 6 foot Fortec....which LNB will work best on it? I know I probably need a HOT lnb for such a small dish, right? Should I go ahead and get a combo c/ku all in one or will a dedicated cband feedhorn/lnb work better? I have two motorized Ku dishes so I don't really need Ku...
Also I see that Sadoun has replacement actuator motors, will that fit on my existing tube? I do not know what kind of actuator it is, it only had a sticker and it is long gone. I took the motor apart and it is full of fine powder, so its probably worn out, but I don't know anything about it other than that. I was planning on just using a hand screw jack on it to keep from running another wire, but on that dish the other day I got had a positioner box with it so I am now considering an actuator if I can do it on the cheap.
See, not asking much...
