Which C Band LNB is Best? | SatelliteGuys.US
siddharthbangalore
2
Hi Guys,
I require some Good C band LNB pls Let me know which is the Best LNB available and Whats the Price.
Regards,
Sidd
Not sure about the best but if you want something great for 4dtv the Norsat 8515 should be good, for dvb and 4dtv the 8215 or the 8115 should work best.
if you have a corotor then i would agree go with the best stability lnb you can get ( 4dtv likes stability)
if its for digital c band and you already have a feedhorn and don't want to spend a lot of money then most of the newer ones do a good job.
if you want a lnbf thats c-band only then the best geosat pro c1 is a good choice ( there is a thread here on comparisons for lnbf )
good luck and ask more questions if you have them before selecting.
I like California Amplifier for C band. Got one running 18 years now. Works perfect with the 4DTV and DVB.
Ive had a Cal amp 17* mini for a few years and it works great.
just moved it over to my new corotor2 from my old Channel master
feedhorn,which was about 20 yrs old.That feedhorn started life with a huge
LNA and a down converter.
GOOD MORNING,
Size of your parabolic antenna and choice of satellites will
definitely channel you towards the appropriate LNB. Would
advise you to visit NORSAT /PATRIOT for stability priority.In the
long run it will prove less expensive and more versatile.
Up to you to decide now.
Best Wishes,
kadnor
Calamp and norsat
I like Calamp my self. they have great picture's i've had one norsat. you cant beat those . the picture is great. it was a 30k i believe...just imagine how the rest are but calamp does the job and i like it . mine is a 25k w/lil red led. on the side lol which is cool!
Maybe he can check with some of our sponsors, I'm sure they can ship to
Bangalore. 4dtv prob wouldn't be a consideration there lol.
jpc1193
