Which is better for 129 sat | SatelliteGuys.US
bhamster
52
Where Killer Whales are free
Have a 1000 for 110&119 and a 500 for 129 had the 500 put up ion Sept to replace a smaller one as 129 wiil not stay in for any length of time call dish and now they want to bring out a 1000+ is this any better to aim at the 129??
To answer your ? re 1000+
...my experience was slightly worse than the 24" separate. Directv is being installed today; I'll let you know if that improves the drop-out issue :)
A 1000+ gives you the equivalent perf of an 18".
Get a 24" for 129W. I use one from SC pointing thru brush and it resolved all signal issues on all TPs, SD and HD. The one mentioned a few posts back has a "D" shaped LNB holder perfect for snug DN LNB fit.
update
Just a quick update, dish was here and put up 24" dish Wow signal is running around 45-50 so it's more than double than before, was running around 17-20 this morning before they showed up..and yes I tipped the tech for a job well done..
For 129, I highly recommend the 24" or bigger dish. It makes the signal stronger. It will also make it easy and fast for your receiver to process the signal.
A moment please
alternative to Dish 1000[.2]?
