Looks like the hail/lightning storms we had in the Atlanta area two nights ago has caused a problem.
System:
Oval dish (3-LNB)
Zinwell 4x8 Multiswitch
HTL-HD Tuner
4 Sony SAT-B3 Tuners
Problem:
All odd transponders show '0' signal strength on all 3 sat's during signal strength test for the HTL-HD tuner. All even transponders are fine (90+) on the same tuner. All of the Sony tuners are fine on both odd and even transponders during signal strength test. HTL-HD has issues 'searching for satellite signal' on some channels, none of the Sony tuners have that issue (go figure). Not only that, but I get an odd SD channel when I tune into HBO-HD and a different SD channel when I tune into SHO-HD on the HTL-HD.
* Tried resetting the HTL-HD (no luck)
* Tried moving HTL-HD line to a different port on the multiswitch (no luck)
So which is it? LNB, Multiswitch, or HTL-HD tuner?
System:
Oval dish (3-LNB)
HTL-HD Tuner
Problem:
