Which LNBs to use with a DPP44 switch? | SatelliteGuys.US
Cyclone
Proud Stiff Member
2,586
16
Maryland
I'm looking to upgrade from my Dish 6000 & 510 to a 921 & 510. I right now have a Legacy Dish500 Twin LNB with a Dish300 for 61.5. They connect up with a pair of SW-21s and run to the two receivers.
I'm going to get the 921 and with the DPP LNB held up, I'm going to go the DPP44 route. I know that I need DishPro LNBs. I'm just confused as to which ones are the ones that I need.
For the 110/119 I see the DishPro Twin and Quad models. Since I'm using a DPP44, I'm guessing that I only need the Twin. For the 61.5, I need a DishPro Dual LNB.
Can someone straighted this out for me?
I'm actually having a hard time finding a DP Single on eBay, I did find a Pair of Duals for $25. So I bid on them.
I did win my DPP44 for $80 :D Hope it isn't a dud. Only thing left to win is a DishPro Twin.
Now these will bolt in place of the Legacy stuff that I'm replacing right?
I am now most excited. I was able to get a DVI/RBG adapter today for $15. Heh, they wanted $30 for it at CompUSA.
boba said:
If you reread what I posted I said 1 cable for each satellite location on a dish 500 that means 2 cables. :)
I know what you said, but I made this statement for newbie benefit...;)
install and upgrade
PVR721 and a Liteon DVD Recorder vcr control?
