Which movies package comes with HD, and which movies package does not? | SatelliteGuys.US
happy hopping
103
North America
With HD, you paid the extra $10 / month, but isn't it true that some movie package already come with HD in its whole set?
I'm interested in HBO and ShowTime. is the entire HD channel come with HBO and Showtime?
Or do you have to pay the extra $10 on top?
First, you do not have to pay $10 for HD for any channels. You have a couple of choices to get "HD for Life" from Dish. It will be no extra charge for any channel you get that is available in HD.
Second, that is the same for any of the Movie packages. If the channel is in HD you will get it in HD. You of course have to have the correct satellite set-up to get any channel in HD.
If you are paying $10 for HD, and want to continue to do so and not get it for free, yes, that $10 covers the Movies Channels to answer your question.
In addition, there are some options. However, not every channel in the package or premium offering may not be in HD.
FMI on...
HD Platinum--
http://www.dishnetwork.com/hdplatinum/default.aspx
Premium Offerings--
http://www.dishnetwork.com/premiums/default.aspx
A La Carte Offerings of Encore and The Three from Epix (none in HD unless you really get Epix 1 and 2--However, I am not sure if those are included in HD a la carte): http://www.dishnetwork.com/premiums/other/default.aspx
So, you would probably want to stick with either HD Platinum or a certain premium offering or certain premium offerings. I hope that helps. Let us know how it goes. :)
list of local news that broadcast in HD
Which 625 is newer? (Yes another trick question)
