Which on do i have? | SatelliteGuys.US
Which on do i have?
mskii4
2
Greenwood, IN
My brother in law dropped off a Dish Turbo HD with the DP Plus triple LNB. (Not Black) How do I know which one I have? They are evenly spaced...if its the 1000.2 do i need to DP Plus separator?
Thanks in advance!
It's almost certainly a 1000.2, which has an integrated DishPro Plus switch capable of driving 3 duo receivers. Duo receivers should come with a separator, but they are available separately.
Also if you are missing the seperator and only have one dual tuner reciever you can connect 2 cables to the satellite feed ports on the reciever and it will work.
What DLAN server are you using with the Hopper?
DVR fees?!?
