Which Receiver to Chose | SatelliteGuys.US
xtraheat
15
I am looking to get a third receiver. I currently have a DP508 and a 301. Will any of the following receivers be compatible with what I have.
311
322
625
942
811
Are there any special things I would need to do during installation?
Any suggestions on which one to get?
:welcome to SatelliteGuys!!!!
Well we really need to know more about your set-up. You may need to add a switch to add a 3rd rx and you may not depending on what you have. Also do you want another DVR or will a standard unit be fine. The 311 is essentialy the same thing as the 301 just has an intregrated Smart Card.
I am looking to update my current satellite system. I currently have 2 receivers a DP 508 and a 301. I have dish 500 and LNB -DP Twin 1. I want to add another receiver and was wondering if it would be a major problem. Will I need a new dish or just a receiver? What would the additional cost be if I choose one of the following receivers:
625
322
311
Dishnetwork is running a promotion I think I can get the 625 for $119 and the other 2 for $99. The price includes installation. I asked about replacing the 301 with the 625 or 322 and they told me I can't use the special to replace an existing receiver.
Going price for a 622
Need SS for D500 @ 61.5
