I see so many different models of Roku for sale on Amazon. Other than price, what features should I look for. Is there a best model(yet not too expensive).
Currently the Ultra is the best model. I dont find any of them overly expensive personally, but if cost and bang for your buck is important, the streaming stick + is probably the best combo of features for your dollar.I see so many different models of Roku for sale on Amazon. Other than price, what features should I look for. Is there a best model(yet not too expensive).
How about htis model at Amazon:
Amazon product ASIN B07HDBZN7Q
The Ultra only comes with headphones. I do not need them.
The stick + and the premier also do HDR. The biggest diff is a slight speed boost with the Ultra, and the ethernet addition. If you are running or planning to run it on wifi, then Id probably go with the Stick + as it has a better remote that the premier. and costs less than the Ultra.Plus the headphone output on the remote if you need it.
The sound is much better using headphones with the remote instead of the bluetooth or wired on a smart phone.
Also the Ultra does HDR, I do not know if the other models do, you can also run the Ultra wired or wireless, all the Rokus in my house are wired so never have a drop.
Sent from my iPad using SatelliteGuys
That one will do most everything that the others offer, but the remote is IR only as someone else stated. I do think the other remotes are worth the cost increase as they are not line of site, and also contain tv volume and power control (and headset capability with the ultra).How about htis model at Amazon:
Wal mart also offers a Roku LT as an exclusive that offers ethernet. Its $79 which normally undercuts the Ultra a bit. However the Ultra is on sale for the same $79, so with that being the case, I see no reason to get the LT instead.I want wired ethernet and it looks like the Ultra is the only model that has ethernet.
Better have a lot of batteries if you use the headphones.Plus the headphone output on the remote if you need it.
I have the very 1st Roku ... in fact, I have a solid clear Roku somewhere that you can actually see thru...that one wasn't released I don't think...but i still have it.
Most recently, I've been buying the Ultras. Got 1 stick, but the ultra is where it's at for me.
If the connection is wifi and it matters if you need 5ghz or 2.4ghz, then the stick doesn't do 5ghz. I do believe the ultra does?? Not 100% on that because I use ethernet.
Limited time offer
