Which satellites can i receive that are not hd? | SatelliteGuys.US
:welcome to Satelliteguys Paul0138!
Use a satellite finder app on your phone to locate where the sats are in the sky. There may be another place you can move the dish to or maybe trim some branches from the trees that are in the way.
If you want SD only service all you need is 101 right now AFAIK. 99 and 103 are not that far off so it's usually pretty easy to get all 3.
99/101/103
110 and 119 are no longer used.
Try SatFinder Lite on iOS.
Reactions: Jimbo
Yeah like TechGuru said it is pretty much all or nothing these days as you only need to hit 99/101/103 which are very close together.
Reactions: Jimbo
