Which Satellites will I need to be able to see? | SatelliteGuys.US
Diansul
52
5
Texas
My location has a lot of trees and want to verify where a dish could be located. Can anyone tell me which DirecTV satellites I will need to be able to see for SD and HD? Or refer me to a site that has this information? My zip is 75605.
Azimuth 202.9 for 101 slot/bird Elevation 48.6 Tilt 67.8
HD =99-101-103 slots, some areas use 119 for SD locals at Azimuth 230.
Use a good magnetic compass to find azimuth.:)
You're going to need to get just about everything, from my eyes.
I looked up your locals at : DIRECTV - Local Channels , and assumed Gregg County
Your SD locals are on 119.
Not 100% sure, but your HD locals are likely at 103 (spaceway 1)
so, you're going to need a 5LNB dish, sorry.
Locals should be receivable OTA not easily because of multiple directions but 45 miles is usually not too hard to receive. So if you really needed a 3 LNB 99/101/103 could be used.
Getting new service. Can I use a friend's extra DVR?
Dish Movement question
