Which signal meter to get? | SatelliteGuys.US
ken2400
1,309
144
Central NY State
I bought a su-200 on a whim and thought it would do more. It works BUT did not scan for existing transponders so I need to use a analog meter with it. I can manual add transponders and it works.
Any ideas?
Get on lyngsat or sathint and program in some active transponders. Then peak the dish with that meter. It is a good meter for the hobbyist. Then scan all you want with your receiver.
New Tp on SES 2
Hobbyist from the PH
