White Springs 129 blind scan Receiver | SatelliteGuys.US
madmadworld
Official TV Watcher
17,034
6,857
up on the roof in SinCity
hi
looking for a true fta Receiver,
any body got one that will blind scan and find White Springs @129* ?
i have a half dozen none will do it.
all the Receivers will pick up White Springs,
IF i put in the tp info myself. but in a blind scan none find it.
my hope is if it would do this i'm not going to miss much sports feeds.
thanks alot
hi
thanks alot
You won't miss much, some FTA receivers have a hard time detecting low symbol rate transponders, usually feeds and sports use higher ones.
I have a Coolsat 5000, Pansat 1500, Fortec Ultra (and a few more) and those 3 pick it up on a blind scan just fine
help with setting up a channel on dishnetwork dish
Looking For Parts
