Who can you call if your satellite TV breaks while you’re at sea? | SatelliteGuys.US
Hey folks, it’s rare but it happens. You may be far from your home port when there’s a problem with your satellite TV system. It’s the last thing you really want to have to deal with. If only there were a way to make it easier.
Tech support is available… for free!​
You probably don’t know much about the way your boat’s satellite TV system works. Chances are you’ve never had to think about it. So if it stops working, you’re probably not even sure where to start.
That’s where the experts at Signal Connect come in. We can diagnose problems remotely and give you the steps to take. A lot of times, there are simple things you can do that will let you watch TV quickly. You don’t need to know how to fix the system or even how to twist a screwdriver. Just call the experts at Signal Connect at 888-233-7563. It will help if you have some idea of what kind of satellite system you have, though. If nothing else, look for the white gumdrop-shaped dome and see if it has a brand name on it. Often times that’s enough to get us started.
Let’s say something is really really wrong​
Suppose a large object hit your satellite dome. Or you dropped a satellite TV in a puddle. I’m talking about the kind of damage that takes a little more than pressing the reset button. It doesn’t happen very often but when it does, it’s nice to know that you have someone on your side.
Call us at 888-233-7563 during East Coast business hours. A lot of times things aren’t as bad as you think they are. We can ship replacement parts like satellite receivers to the nearest port and guide you through the activation process. If you need more help than that, we can usually set it up so that a marine installer meets you at port to work on what you need. In rare cases we’ll even be able to send someone straight to the boat. As you would imagine, that can be a bit pricey.
It’s good to know you have a friend in the business​
Signal Connect has been helping boaters for over two decades. We’ve done more satellite activations than anyone in the world! Whether you need help with satellite television, internet, cellular, networking, or anything related to your boat’s entertainment systems, call us! We can help. When you call 888-233-7563 during East Coast business hours, you’ll reach an expert who can guide you through the whole process of getting things fixed. We’re DIRECTV, DISH, Viasat, and Starlink dealer and we can help you get what you need. Call us, or if it’s after hours just fill out the form below. We’ll get right back to you!
The post Who can you call if your satellite TV breaks while you’re at sea? appeared first on The Solid Signal Blog.
Continue reading...
