Tried reading and haven't found out if orby owns dish and antenna once its installed or is it yours?
I can see the account sharing already.. Guess I'll call and have one set up.The customer owns all equipment.
I just seen the Orby ad and found your site while trying to find out more info. I see they say $150 for installation but gather from this forum that you can elect to install yourself? I am a old retired analog engineer and set up several directv systems on our homes before they went to the fancy multi-satellite ones and before that set up several C dishes here on the farm. Would I be correct in assuming Orby uses only one satellite since it appears they use a single LNB. I currently has Directv but am fed up with paying a 100 bucks a month and only watching 3-4Given its limited application (due to its relatively small size and linear LNB), does it matter?
How bout the older directv single lnb dishes. I have one that is likely 15-18 years old. Just hate investing much into orby before I know ifWelcome potluckman!
Self installs were done by those of us with our own dishes, LNBF and satellite meters. With that said, your DirecTV dish is not suitable as it is designed for multi-satellite reception and the multi-feed LNBFs are the wrong polarity (circular) and frequency range (12.2-12.75GHz). As a hobbyist, one might fabricate a LNBF holder to place a linear LNBF (LO 10750 Freq range 11.7-12.2GHz) at the correct sweetspot, but the dish would still perform as one with a smaller than acceptable diameter.
In your case, I would suggest that you are a perfect candidate for the OrbyTV install. By the time you source your own dish, linear FSS LNBF and attempt to install without a meter, you are better off getting the OrbyTV dish, LNBF, diplexer, OTA antenna and install for only a little more in cost.
Limited time offer
