Who Sells 4ft or Bigger Prime Focus Antennas | SatelliteGuys.US
derdude
116
Is there anyplace on-line that still sells prime focus satellite antennas? I am looking for a 4 or up to 6 foot prime focus dish to use for GOES satellite reception.
Thanks...
Depending on where you live.. a few have purchased from Tek2000.com w/ mixed results.
They're a Canadian dealer priced in US currency and US shipping fees which turns off most Canadians (ie 40% exchange rate)
Ebay might be an option along w/ your local classifieds.
Cheers, K
PS- There is a used dish thread in the Cband section
Thanks...
fixed or with a motor? you can pull in C-Band with my egg its q 4 foot, back then it was doing what a 10 foot dish could do, but not sure how good or bad it would be with 2 degree spacing never fired it up, because it was missing a part, then I found that part years later from another dealer but I lost a reason to play with it, I use it to cover my fig fig tree with, have a fixed mount for it the feed goes in the BACK OF THE DISH, YES IT DOES.... READ UP AND LEARN
Reactions: k.r.
ASC-1 locking up when restoring from backup
Master list of All Satellites for download?
