Whole-Home DVR problems | SatelliteGuys.US
glen4cindy
641
38
St. Louis MO, area
I'm using my home network for my Whole Home DVR.
All of the sudden, my Genie cannot see ONE of my networked DVR's.
THAT DVR CAN see the Genie, AND all the others. Every other DVR can SEE all other DVR's.
There is just ONE DVR that the Genie cannot SEE.
I have RESET all DVR's, Routers, ETC. involved.
Nothing in the home network setup has changed, just from one day to the next, the Genie cannot see one of my DVR's.
No other issues with any other aspect of the system.
Thanks in advance for any assistance.
Is all of your wiring direct? no secondary splitters, no thru the window opening / flat cable installation?
I had problems initially for the first 2 weeks until I let them drill holes in the outside walls to do direct cabling .. since then near zero issues...
till this past month ... in which I've been noticing more issues with the genie. I've not updated from one of the previous CE's in a while ... may do this weekend.
I'd also check under - menu. There's an option to only show your DVR. Maybe you accidentally switched it.
Blaze Craze on Facebook
Refer a friend
