why am I blacked out on ESPN alternate? | SatelliteGuys.US
Lkr
1,792
I thought if the game was an OR game on espn2 i would be able to watch it on the alternate channel. it has always been that way for me. ESPN2 is Arizona St vs Wisconsin while espn alternate is nebraska vs washington. In the past, I had been able to watch both, but I'm now blacked out on the alternate - why?:confused:
Check your local ABC station, that should be the reason you are blacked out on the alternate.
Here is the map for today. Check the color you are located in and then read the bottom of the map. It tells you what channel the games will be on.
ABC September 18 Regional Map 3:30 PM Eastern Games | HD Sports Guide
Alabama/Duke is on ABC
Ok so you are in the south. Then looking at the maps you should have:
Arizona St/Wisc on ESPN 2 HD
Nebraska/Washington you need ESPN Gameplan or can get it on ESPN3.com
Alabama/Duke is on ABC HD
There is no game for your region on the alternate channel
Tonight your region should have both games in HD......Texas/Texas Tech on ABC HD and Notre Dame/Michigan St on ESPN 2 HD
Thinking about directTV
can only receive sat 101.
