Why am i loosing channels on G-10 KU | SatelliteGuys.US
neil_kc1
402
21
KANSAS CITY AREA
I seem to be having a problem with channels on G-10 KU. Channels that once came in clear now are all broken up. They all seem to be on the same transponder or two. Not all the channels on G-10 are bad. A lot of the channels still come in as clear as ever. Any suggestions as to why? The weather does not seem to make much difference.
I don't have any problems with G-10, but of course I have an 8ft dish. You might want to check your adjustment. I notice that on occasion the wind will blow the dish just a tad out of alignment so I have to bump it around until I get a good signal then re-enter the settings. Give it a try, you never know.
Equity is screwing around with 11719 transponder. This has the tube, Lick Tv, a couple spanish channels on it. One day its a 75 quality but latelly iots been right around 34-35 (30 is the cutoff on mine)
If you're getting good signal on the rest, then you should be oK. Its on Equity's end
i have noticed also that on galaxy 10r ku that 11799V used to have a quality of 72-75% now i have 60-62% on my pansat 2500a in Charleston , wv. 11719 tp is now at 42% and it jumps up and down to 35% (it used to be 75%). i can't remember the tp frequency for kdkf and the k??? channel that has the symbol rate 4444ms/s. That transponder rocks ot has 87% signal lever and 90-99% quality. I am using a pansat 2500a, 60 cm patriot with moteck sg-2100 motor, diseqc 4x1, rca in line amp.
tp 11718V on galaxy 10r is acting up again pixalization on all channels (tube, mas musica, etc) breaking up bad. pansat 2500 A is locking and unlocking on this tp. all other tp's are good. Let me know if any one else is experiencing this right now.
It was unwatchable for me with my DVB cards Friday and Saturday, but is OK now. That tp is really acting up.
i just turned on galaxy 10r on the 11718v tp and its all good again quality around 60% on pansat 2500A. Anyone having trouble with the tube, lick tv, and some of the other channels on this tp, don't just assume its your problem. If you are getting good signals and reception on the other tp's its not your dish or equipment. Equity is having some issues with 11718V.
dang
mine is still at 33...no pixels but not the best quality...and no its not the equipment :)
All the other TP's are fine
My xmas gift to me, I got my BUD up and running
How about analog receivers?
