Why can't I set a series timer for ABC during PTAT? | SatelliteGuys.US
smokey982
2,050
161
Cleveland, TN (Chattanooga Market)
I just noticed I can't set any series timers for my ABC channel during prime time anymore. All the other PTAT channels work just fine. But for some reason when I click on a show to set a timer. The only options I have are "daily schedule" and "more info". I don't know how long I've had this problem because most of my timers I've had set for a long time and haven't tried setting a new timer for ABC in a long time. I don't know if this is an issue created by the last software update or if maybe it has something to do with the blue timer dot that appears at the 7:30 time slot everyday. Has anyone else had this issue?
Sent from my iPad using SatelliteGuys
I just tested it and I get the same thing ABC only...weird. Maybe DIRT can look into it.
I am having the exact same issue. I saw another post where another person is having this issue as well. Last week it fixed itself when I unplugged for over 1 minute. But problem came back and now unplugging does not fix it. Also, may be related: I have had last show of PTAT day on ABC get cut off before program is complete. Very annoying. No solution so far.
Charlie Ergen's interview with All things D
Can't set timer for San Francisco ABC affiliate
