Why do I get more info screen? | SatelliteGuys.US
Dolfan
Sometimes when I directly enter the channel numbers I get the more info screen. Then you have to go to another screen and click watch now to get rid of it. How can i stop that?
Also how do you direct tune a station by channel number wothout entering all four numbers? If i want to go to seven why can't I just punch in seven and enter? When I do this I get the error beep and usually the dreaded more info screen.
We have a HR20-700 and a HR21-700 and have no problems with them changing channels, if I want to go to channel 7 I enter just 7 and it will change to that channel with no info screen.
What remote are you using and what version software is on your system and are both units doing it?
HD channels going out only in the afternoons - fixed
Check out TLC-HD now!
