why do some channels not switch immediately? | SatelliteGuys.US
Lkr
1,792
The sports channels(400s) do not switch right after typing the number in. My universal remote has an equivalent for the select on the Dish remote, but it is not a quick process(really only use this remote for DVD player, but sometimes it is the only one I grab). Is there any reason this happens?
If you have no clue what I'm talking about, just hit 402(if you have platinum HD), or your RSN(400 channels) and do not hit select. Notice how long it takes. Then punch in a normal channel.
Why does it not wait though on a channel in the 100 section, the 200 section, or the 300 section as well?
It could be that is because DISH does not have channels in the 1000, 2000 or 3000 ranges. There are channels in the 4000 range however. The receiver may sense this and know that a fourth digit would not produce a channel in the system and tunes to the channel after three digits have been entered.
This is a guess on my part.
Need help with service call !
Pointing a lone dish at 129
