Why has Pandora stopped working? | SatelliteGuys.US
I WANT MORE
434
92
"Middle of Nowhere"
I have an HR54, HR24s, and C61Ks.
Pandora no longer works on the HR24s.
I receive the following message: "There was a problem connecting to the internet. Please test your connection."
My internet connection is fine.
This is a dumb question..but do the other apps work on the HR24? I assume you checked the ethernet cable?..maybe reseat it if it looks like it's good..is there an option to refresh the internet content?..maybe the app needs a software update..
Sent from my SM-G920V using the SatelliteGuys app!
All other apps work fine. Pandora also works fine on the HR54 and C61k.
I had mentioned this issue in another forum/thread and it appears there are other with the issue.
It was suggested that I start a separate thread for the issue that might attract additional feedback.
It could be the app needing a software update..is it possible to remove it and re-add it?
Reactions: larry55
SloMo Bug in HR44 with some channels
C51 Installation
