why is Directv Audio So LOW frustrating | SatelliteGuys.US
secfreak
26
pa/nj
does anyone now why Directv audio is so low i have tried everything .... compared to my local cable company and ota its like you have to turn the volume 2x as loud to get the same level......:confused:
I only use the speakers on my tv and its very low for me. My cable was louder as is my xbox/playstation. Is there anything to try?
I use my home theater at all times. Everything is ran through it so I don't notice it either but I've noticed in the bedroom it is a little quieter but never really gave it much thought. Normally laying in bed so don't bother me
Mine is the same way. I have the Satellite/Cable input Source Level on my Denon turned up to like +6 while the other inputs are 0 or -3 or so. The input was around 0 when I had cable plugged into the same input, same HDMI cable. Do you find the Pandora "app" on the directv receiver is a "normal" volume, and must be turned down by half or normal Directv receiver operation when using Pandora?
Actually I haven't. But in normally not in the same room when I use pandora. Ill turn it on and then crack it up and walk away. But, guess I got a something to test this morning when I get out bed :)
reset everything on Directv H34 system
2013-Things I would like to see happen with D*
