In this forum Dish Network always has 1000 viewers or so and Directv usually has around 250 people viewing these forums at any given time. I always thought Directv has way more subscribers than Dish Network. Just curious.
I second thatProbably because Dish Network subscribers are having more problems.![]()
Well more precisely, there is a lot more complaining on the other side. Just came from there. There are always threads on when and where is the HD. Not having as much HD, VOD or Sports gives more time to surf the net as well.Probably because Dish Network subscribers are having more problems.![]()
SatelliteGuys.US was originally geared for Dish Network subscribers and alternate to DBStalk which was largely comprised of Directv subscribers. Hence the higher population of Dish people here.
D* has 30sec skip and 30sec slip (you see the ff action while it skips).So whereas this is a Directv Forum on this basically Dish Site....I have a question about the D* dvrs. Is it true there is no 30 second skip button to skip over the commercials when playing back a recorded show?
I am thinking of making the switch over to D* to get all my locals, my rsns and baseball fix (YES and mlb net) in HD. Something that will probably never happen here on Dish.
yes there is a delay, its just like your computer... it delays when you tell it a command... thats what the recievers are... computersMr Charlie Ergen claims his dvrs are the only ones that have that feature.
How about a delay while switching channels on the HD DVRS?
The first few days I noticed a definite speed difference from the 622 I had with DISH and the HR22's I have now. Now I don't notice any speed difference in changing channels but the guide and menus can be described as a little slower than E*'s but not to deter anyone from making the switch. I remember the switch from analog cable to digital sat and thinking the black screen that pops up between channel changes being bad. Now it's nothing.Mr Charlie Ergen claims his dvrs are the only ones that have that feature.
Yes, just like on any receiver from any company. Usually 2-3 seconds but may be quicker or slower depending on various settings you have and if you use HDMI or not and how well your TV's HDMI syncs. Lot of variables involved.How about a delay while switching channels on the HD DVRS?
HDMI doesn't play any speed role unless you have Video Resolution Pass-thru enabled. By choosing 1080i or 720p in the menu this point would be moot.... Usually 2-3 seconds but may be quicker or slower depending on various settings you have and if you use HDMI or not and how well your TV's HDMI syncs. Lot of variables involved.
E* is adding BET Jazz-HD today so that may be enough to keep you where you are.If E* keeps adding all of D*'s HD channels a year later, I still made the right choice not to mention all the money I am saving for the next 2 years. April 1st will be very telling for E* when the viacom channels get added; if they don't go in the turbo packs, I see a lot of subs leaving for the true hd leader.
I am a little confused on why there are many post on turning pass-through OFF to speed up channel changes then. I see how changing from a 720p channel to a 1080i or 480p makes the hr2x have to rehandshake. But when forcing 1080i on the receiver, if the guide or miniguide stays on the sceen the whole time when changing channels how is there a handshake going on?HDMI handshaking does indeed play a speed role in channel changes, or at least seeing them on the screen. Many a person has had 8 second channel changes using HDMI and goes down to 3 seconds with component without changing any settings. It only comes into play on TVs with bad HDMI handshaking, usually it's not talking properly to the receiver. Many threads on DBSTalk, in the early days especially, on this. I'm sure there were some here as well.
Limited time offer
