I thought the Hopper had a 2 tb hard drive, if that is the case why is my DVR menu showing it is already 8% full with 5 recordings? At that rate I will be out of space by 60 recordings or so. Is it counting PTAT? I have only had it since Monday.
yes I use PTAT. But I thought that was on another partition and did not count towards your DVR totals.Do u use ptat? I have 1 recording becides ptat, and it says 4% used...
At 7% used, that doesn't sound like the advertised 250 HD hours.I have 105 hr 38 min HD/812hr 32 min SD
I wish it would relinquish the PTAT space, when PTAT is disabled. It's a huge waste of space for those of us that do not use PTAT.
It appears that way.So are you saying that if PTAT is not enabled, the Hopper still only has 500GB user space?
Allamand said:So are you saying that if PTAT is not enabled, the Hopper still only has 500GB user space?
Allamand said:So sad, I already paid for the EHD functionPlus I now read that the Sling will not see anything from the EHD...
Not sure about the sling issue, but the simple solution is to transfer something from the EHD to receiver if you know or think you might want to access it via sling in the near future.
No. It would be much better to not allow enabling PTAT when there isn't enough space for it. It could easily display a warning message alerting you there isn't enough space to enable, and if you wish to enable, you must free xx amount of space by deleting recordings or transferring to an EHD.A user can turn PTAT on at any time so that space has to be available for it. Otherwise, imagine the uproar when someone is using that space for their recordings and someone else in the house turns on PTAT. There go some recordings out the window to make room for PTAT. Much better to leave the user accessible capacity at a fixed amount. Besides which, attaching a EHD is free now.
GaryPen said:Are you saying that recordings from WA satellites take more hdd space?
GaryPen said:No. It would be much better to not allow enabling PTAT when there isn't enough space for it. It could easily display a warning message alerting you there isn't enough space to enable, and if you wish to enable, you must free xx amount of space by deleting recordings or transferring to an EHD.
They also don't need to reserve so much for pre-downloaded VOD. I can stream any VOD programming I'm interested in. I don't need 1.5TB space wasted on my HDD for features I don't use. (I'm not sure how much of the 1.5TB is reserved for PTAT and how much is for VOD.)
Limited time offer
