Why is RG58 cable so expensive? | SatelliteGuys.US
RG58 cable can be really pricey. Take for example this 1000-foot spool, which at over $3000 is a real price premium over a RG6 cable, which can generally be found at less than one-twentieth the price. RG58 cable is used for older industrial installations and can still be found in professional-grade cell booster installations. The traditional wisdom is that 50-ohm cable like RG58 is more compatible with sending voice and data signals through the house, while RG6 is better for video.
RG58 just isn’t that common​
Unfortunately, while RG6 has enjoyed great success as part of pretty much every cable TV, satellite or TV antenna installation in the last 40 years or so, RG58 cable has stayed out at the margins. Even most consumer-level cell booster installs use RG6 cable now, which offers similar (if not quite as good) performance for relatively short runs. That leaves RG58 as an unpopular alternative, and that’s the real reason it’s so expensive. RG58 just doesn’t get produced as often and so each spool carries a larger percentage of that “startup cost” that comes with manufacturing anything.
Plain and simple, if you’re going to make ten million feet of RG6 (and the real number is probably ten times that) each foot only has to absorb a small part of the cost of getting the manufacturing line running. On the other hand, there’s probably not a market for more than a few hundred thousand feet of RG58, so each foot is going to cost more.
What makes matters even worse is that converting from one cable type to another is expensive. You need special converters that step the impedance up or down, not just plain adapters. Not only that but the process creates so much loss that you’ll usually want to put an amplifier in line to deal with it. Yes, it’s a pain but you’re better off just using what you need in the first place.
Options for replacing RG58 cable​
If you’re looking at a complete re-wire job, it’s a perfect time to pull out the RG58 and put in RG6, even if that means changing cell boosters. Cell boosters that use RG58 cable are intended for real industrial use and that makes them expensive too. Sooner or later you’ll be glad you moved to a booster that uses easy-to-get low priced RG6 cable.
There’s another option if you want to stay with 50 Ohm cable. Most new small to medium sized installations don’t use RG58 cable. Instead they use LMR400 cable. It’s still generally more expensive than RG6 cable, but it’s often about one quarter of the price of RG58 cable. It has excellent loss characteristics and is available in pre-made lengths. One of those is probably going to be perfect for your installation. Consider that RG6 compression tools don’t generally work for the N connectors used on 50-ohm cables. When you think of it that way, premade cables might just be the way to go for you.
Shop for the cables you need at Solid Signal​
When you do shop for cable, of course I certainly would appreciate if you would take a look at SolidSignal.com. Solid Signal has all the installation accessories you need for any size job. We also have expert consultants on hand to help you plan that large project. We know some projects are a little too large for you to handle on your own. In those cases we can even recommend an installation pro in your area.
If you need personalized assistance, call us! We’re here during East Coast business hours at 888-233-7563. If it’s after hours, no problem! Fill out the form below. We’ll get right back to you!
The post Why is RG58 cable so expensive? appeared first on The Solid Signal Blog.
Continue reading...
ear
Continue reading...
RG58 is not a substitute for RG6 or vice versa. In amateur radio you can get away with using RG6 however most transmitting gear is rated for 50 ohms.
RG8X is a good sub for RG58 since it has lower losses. And there is no substitute for buying good quality coax.
