Why no DishPro +plus Quad or Triad? | SatelliteGuys.US
Mike500
1,338
Thiepval
A DishPro +plus Quad or Triad would be the ideal setup for up to four dual tuner receivers for a Dish1000 or a Dish500 and a wing dish.
This would eliminate the need for the expensive DPP44 on many multi receiver installs.
If it is difficult to place a fifth female F81 port on the current DishPro+ twin, just give us a DPP Triad.
It should not cost that much to add a port on the DPP Twin.
That way, I can simply use up to three dual tuner receivers with separators.
that would be to easy. dish doesnt want to make our lives easier.
Anyone remember the DishPro single lnb? In order to use it with a DishPro Dish500 cascade, you had to use two DP21's and a power passing splitter.
They finally got wise and came out with the DishPro dual.
pointing at 61.5
Please help me
