Wifi internet connection 622, Hellboy & Remote Setting | SatelliteGuys.US
birkoff
94
5
I noticed while surfing E* site that you can set your 622 from
your iphone while sitting next to Hellboy at a business meeting.
So I read the instructions and it says I need to plug in a internet connection.
I looked around and the closest line is 40 feet away....but I remember I got
a wireless thing that connects to my Xbox 360 so I could be on line....so I
plug the plastic thing into the 622 USB and just like my PC, it says, Unrecognized
new divice. So is there a way short of stringing wire to my 622 to get a
internet connection to the 622? Works fine for my Xbox.
Birkoff
You have to go to Set Up>Installation>BroadCOMM and activate it. Occasionally BroadCOMM will need reset. I believe the short cut is MENU, 6, 1, 9.
For about $10 you could buy a wired router so that both devices could use the Wireless Gaming Adapter without have to manually choose between the two. Heck, ask your IT guy. He probably has a couple spares collecting dust.
New to Dish - Local Weather
Dish.sling.com picked wrong the channel
