hello to every one.
now we started to install WILD BLUE dishes is there any tips or advise on how to make it go smother or faster?
i did couple of them so far and it takes me about 7 hours.
o, and while you will get the answers to whatever questions you have on this board... you may also check out the broadband forum here.
Well if your net connection works on the laptop that shows the connection is good and is working. Now on the customer machine all you should half to do is plug the connection into their machines. If they can not get on the net on their machine but you can on the laptop. Well then it could be many things on the Customer machine that is causing the problem like a software setting so forth.
thanks for the replays.
my biggest concern is not the instal of the dish it is setting up the system and computers as far as our training went they said only Window XP and Vista what other systems will it work?
Do most just use the laptop and leave it? Or go through the whole cookie plug it in, set the dishmail.net homepage, go through the outlook, etc?
Touching some of the keyboards are nasty, pubic hairs, boogers, nicotine, you name it.
Reality is most of the customer computers are already gangster with viruses, billion startup items, takes you forever on a reboot, in which it only needs to be rebooted 3-4 times.
Very true. I guess I was more interested in Wild Blue's requirements for completion of a job. If by establishing a connection...whether by tech laptop or customer computer...is all that is required, then that's the question I was leading to
Limited time offer
