will 921 record HD local s | SatelliteGuys.US
iceshark
533
Pacific Northwest
I currently have Voom. It has OTA guide for all OTA channels. Little confused about the jargon used about this on 921. I subscibe for local with Dish. So will I have guide and be able to record HD local channel programming?
Thank you
Thank you
If you currently get a guide for your locals then when you get a 921, :yes yes.
if you have an antenna connected and you have scanned all your local digitals then yes but it showes up as recording on the dish channel even though it is recording on the local ota channel also you wont be able to watch a diffrent ota channel while you are recording on one. but you can watch a sat channel
Installation question
Will DishNetwork Lease 322 and 522,s in the near Future?
